1 - 2 of 2 Posts
Will a buschur 3in DP work with a Apexi Dunk catback? It doesn't seem like it's going to reach the catback and at the start of the catback, there's a flange there. I know i will eventually have to cut off a part of the catback if it does reaches. Also, the catback pipe seems a little bigger than 3in. Anyone know if it will work or anyone running this setup. Any comments would be nice.
I run a 2.5 buschur DP to a 2.5 TP to the Dunk. I had to custom fab a longer test pipe to compensate for the bottle neck piece apex'i provides that takes the cat back down to the stock size. That piece is about 3 inches. Obviously you dont want to use it, so you have to find an alternative. The only other that I know is to buy the whole apex'i turbo back. Which is more resourceful?
1 - 2 of 2 Posts
