Does anyone know what the barometric pressure switch is????? My car is showing a CES light and this is the code. I've read the manual and tested to harness and the plug. They are good. In the manual it says to replace the sensor. Is this inside the MAF itself or what??? OH my car is a 90 model Laser(turbo) with a 92 model motor.
didnt i tell you it was in the mas like a week ago?
nm i agree with him swap the mas and check your ecu for caps damage. had that happen on my car turns out it was the ecu fried
Yes u did tell me that a couple of day ago. i replied that i didnt have another MAF to test and that the ECU is a freshly rebuilt unit that i had to have so that the 92 motor would work in the 90 model car. So i know that there isnt anything wrong with the ECU. And the other codes that it is throwing is the TPS and the Ignition Coil. But i fixed the Ignition coil last night.
