1 - 18 of 18 Posts
my mods are listed in my sig.
I will also have a 3000GT VR4 fuel pump, and 2.5" UIP
can i safely run 18psi?
so i wont damage anything by hitting fuel cut? and I wont damage anything running 18psi without a after market exhaust? just wanted to make sure no money for the exhaust for a few months at least.
how will i know when i hit fuel cut?
I will have to agree with Blackboost. It's a lot safer if you some fuel upgrades. I ran 20psi with no fuel mods and eventually ended up with a hole in a piston. :(
Discussion Starter #6
darn, ok but I know I needed these things before anyways.
what mods am I missing?
go by what is just in my sig.
with the EGT and 550 injectors i know what those are.
the S-AFC what is that exactly? and what companies make good ones?
Stands for Super - AirFlow Converter. It's a type of fuel management unit made by Apexi. You can get one at most major DSM vendors.
Also with the VR4 fuel pump I'm sure you will need an adjustable fuel pressure regulator.
Discussion Starter #9
oh gotcha :) that must be the blue thing i see people have.... what all information does that tell you?
nope from what I was told the 3000 GT VR4 pump is 180lph and is enough to let you run 20psi with a 16g and does not require a fuel pressure regulator the ecu can handle it just fine by itself :)
The S-AFC will let you fine tune those 550 injectors and let you use a 2G MAS which flows a lot more than the 1G one. Other mods that you should trow to the mix:
1. 2.5" or 3" exhaust system.
2. Port job - wastegate hole, exhaust manifold turbine housing and O2 housing.
3. Remove lower honeycomb on 1G mas (if you're going to stay with it).
Discussion Starter #11
quite a bit more has to be done it looks like, but I want to play it safe so I dont blow my car up, I'm really looking forward to going to the next years shootout :)
listen to blackboost. you will be good with that fuel pump and no regulator. get a FULL exhuast as your next mod. you will have a nice increase in spool time and hp. run 15psi for now until you find out what you are doing. get an egt as well. http://www.westach.com/products.htm sells good ones for cheap. use the best gas you can get
Discussion Starter #13
i will save up for the full exhaust and get the UIP first. I really can't afford to ruine an engine or my life doing it :)
on a side note, does anyone know of some 52mm egt gauges that glow orange or red to match my 1g dash lights? i want a very accurate gauge though, my automeeter boost gauge is pretty sad (its off by 2 numbers) ;)
The Autometer Pyrometer Gauge wil do the trick for you...
Sorry to interrupt, but isn't 18 psi too much on the stock turbo? Man!!! if can run 18 psi on the stocker, why the hell am I buying all these mods for, if all I need is some serious boost increase? I have bought just about any bolt-on theres is; T3/T4, Speraco intercooler, AVC-R, S-AFC, 3" downpipe and exhaust, a/f, boost, and egt gauges, Greddy Type S BOV, Turbonetics Wastegate w/9psi spring, 2600 ACT Clutch kit, 255 Walbro fuel pump, regulator w/gauge, 550CC RC eng. injectors zzzz ... you name it. The list is just too long...but 18 psi??? I didn't know these suckers could take that much pounding!!!
Honorary Moderator
18 psi isn't too much for the 14B, but it's pushing it. You might be thinking of the T25.
You're buying those mods because the T3/T4 will outflow the 14B by miles, and can support 25 psi with no problem. It's the flow rate that is most important, not the air pressure. At 18 PSI a 14B is starting to max out, while a T3/T4 is just hitting it's sweet spot.
1 - 18 of 18 Posts
