OK, I drove the car to work, everything was normal, only thing that I can remember that could have anything to do with it was when I was shifting from second to third, and it missed shifted. When I came up to the last red light that is 20 feet away from work, I noticed the shifter could not go into second gear at all. It went in first, 3rd, 4th, 5th and reverse very smoothly. The light turned green and I had to go from first gear into 3rd. I pulled into the parking spot, turned the car off and tried putting the car into first, it could not go into first at all. Second cannot go into gear either, and this is with the car on or off. They cannot even be forced in. Every other gear goes in with no problems whatsoever.
I looked at the linkages and they are all fine, so is the shifter under the center console.
You guys have any idea what could have happened?
