1 - 2 of 2 Posts
My stock t25 is boosting 20lbs and the stock boost controller and all vacuum lines are all hooked up. I need to make it work cause i dont have the right fuel injectors to support this much boost. Any suggestions on what could be wrong? I'm having alot of problems with this car after the rebuild.
The line is probably clogged. Hiding boost pressure from the wastegate spring. Just Like a manual boost controller. Run the hose that goes to the solenoid straight to the wastegate. Bypass it If it still does it replace the whole line. If it still does it replace the wastegate actuator. Or just replace the whole thing with a 14B or T28!
1 - 2 of 2 Posts
