1 - 7 of 7 Posts
i have a 91 talon tsx and it will not start all i get is clicking noise from the metal box behind the radio (no not the ecu) . The car was cranking fine I had an extra starter and i changed it but still the same problem, the old starter got tested and its good. The battery is also good could it be a the starter relay??? or the clicking metal box (what is that called anyways) thanks in advance...
Check your connections... Make Sure You have a Good Ground and Pos... When you go to crank Does your dash lights Blink?
Check under the dash for any loose or dissconected ignition wires..
I did a search and found my clutch pedals switch was bad fixed it and workes fine thank you....
1 - 7 of 7 Posts
