1 - 6 of 6 Posts
I don't know what causes this, but, every time I floor the gas pedal and then release it after a hard run, it always dies out....but, if you drive it normal, everything is good...Could the fidanza flywheel I have, cause this problem?...As for my car specs, cut & paste my sig.....Any help would be appreciated!!
There are many reasons why your car would start and then stop immediately. You can try cleaning the idle air control valve to see if it resolves the problem. Sometimes there is an electrical issue inside the idle air control valve that prevents the valve from operating properly. Kodi nox
1 - 6 of 6 Posts
