Car is running too cold.
512 Views 4 Replies 4 Participants Last post by  crunchymilk
I have a full bolt on evo 3'd 96gst with a slowboy fmic.
Here in Texas I'm used to 80-100 degree temps, even in November. I have No overheating problems, even in hot weather, even with my big FMIC. Fan kicks in right when it should, and temps go down. Well, we recently hit a cold front (around 40-50 degrees at night, and I've noticed that my car will not warm up. The temp gauge rises only from below the bottom, to the very bottom, that's it. If i idle it long enough it will come to where it should be, but then as soon as I start driving around and expose the car to this cold air, the temp goes all the way back down.
From the searching I've done, this might cause the ECU to not get hot enough to wanna enter open loop mode. But it enters open loop just fine at normal times. I know the car has a normal operating temp range, and that I'm obviously not in it if I'm always at the bottom. I have a long trip coming for thanksgiving that will be most likely be in this weather, and I would like to know if I'm causing any damage and how to go about fixing this, or if it's fine. Thanks for reading, any input is appreciated :thumb:
1 - 5 of 5 Posts
noreaga is right, your thrermostat has probably gone bad
Agreed. Its a 99.9% chance. Just changed one on a colt 2 days ago for the same reason. It warms up at idle but as soon as you start moving it will not go past the bottom marker line. Not too hard or expensive. Good luck.
thanks guys
1 - 5 of 5 Posts
