1 - 13 of 13 Posts
I Just Got A New Engine Installed Everything Is New From Top To Bottom .i Took It To The Tuner Shop Got My E Manage And Boost Controller .the Tuner Shop Took It Out For A Couple Of Runs Everything Is Good Except One Problem. The Car Smokes. Once I Take Off. So Now I Have The Tuner Shop Saying Its The Valve Seals I Talked To The Company I Bought The Engine From They Say Its Impossible .they Checked My Turbo Its New I Need Help Or Some Advice Thanks Guys Because Its Turning Into A Guessing Game ,and You Guys Know What That Means
Please step away from the shift key! Our program gets rid of all caps like you're typing in. Please use the shift key and make your post proper in the future.
Good luck with your issue. I'll check back in awhile and see how you're progressing.
Any more info on the Motor? Did you buy it built or did it come out of a Donor car? I would investigate where it came from.
Discussion Starter · #4 ·
I bought the engine from a company called SHOWDOWN MOTOR SPORTS.The engine was built with Eagle rods,Manley pistons ,bearings ,And the head has HKScam shafts . Everything is new from what i know .So im hoping ,or everything better new .
Discussion Starter · #6 ·
I know ,but to smoke that much,The tuning shop did a leak test,and said that the #1 cylinder was at 90 percent,and the #2 was 20 ,and the #3 was at30,and the #4 was at 50 percent ,but would it smoke that much ,and burn that much oil . 4 runs and half a liter of oil was gone . Compression test says pistons are 100 percent
mosers said:
White,and im just getting the hang of this .Take it easy on me
Its all good, I thought it was cute :rolleyes:
Check your antifreeze levels often, you might be burning it, which would be bad. Also check to see if antifreeze contaminated the engine oil. You can look at the dipstick, or look at the under side of the oil filler cap. If the oil is contaminated with antifreeze, it will have the appearance of a chocolate milkshake.
Discussion Starter · #10 ·
Cool ,so you dont think its from the valves.Im telling you these guys are driving me crazy ,and their the closest shop to me ,and thats 5 hours away .
Well unless its just regular break in like Red stated, a lot of white smoke is bad. Bad valve seal would allow oil into the cylinder, resulting in blue smoke. White smoke is caused by burning antifreeze. Only way to burn it is a bad headgasket or a crack in the block. Hope you have a warranty.
+1
1 - 13 of 13 Posts
