The oil return will cause smoke, also there is great info on rebuilding turbo's on vfaq.com.
vfaq is only for 14b, 16g, etc. I've been trying to use that as a bases. I got a new gasket so im going to try to replace it and see if that helps. Thanks.gvr4dsmer said:The oil return will cause smoke, also there is great info on rebuilding turbo's on vfaq.com.
Hopefull this wasn't an Fp T28. How many miles? I guess I retract my last statement, turbo it was!!!!smitty1gbishi said:the center section just fell out.
Well that sucks, always a good idea to buy brand new. Also sounds like someone down the road in its life it wasn't treated that nice. FP does have an awesome deal going right now, 599 for the T28. I'm going the route. Were you satisfied with the performance of the turbo before it started to smoke? I've usually only gone the 16g,20g, larger turbo route.smitty1gbishi said:from what i know it was a FP it wasnt brand new though it was used. I bought it off of here. I had it on for about a month until I started to see smoke.
Yeah i loved it. It still pulled strong after it started smoking but i turned the boost way down when it started. I was running around 16-20 psi and it pulled like a mofo.belittle said:Well that sucks, always a good idea to buy brand new. Also sounds like someone down the road in its life it wasn't treated that nice. FP does have an awesome deal going right now, 599 for the T28. I'm going the route. Were you satisfied with the performance of the turbo before it started to smoke? I've usually only gone the 16g,20g, larger turbo route.
