1 - 6 of 6 Posts
Hey all, well after Mitsubishi told me that my check engine light was on (95 GSX) and I replaced the O2 sensor, there it is again. The guy at Mitsubishi said "see you should have fixed it here" (it was $240 as opposed to my $80, who would?) So I am thinking that maybe it is the wiring from the harness that you plug the O2 sensor into (on the passenger side of the head.) I still (like with the "broken" O2 sensor) get about .068 volts when I use my voltmeter on wire #76 from the ecu. My Autometer air/fuel gauge still obviously doesn't work... Any help would be much appreciated. Thanx!
Founder/Former Owner
Have you found out what code (for the CE light) the ECU is putting out?
** Ted-95 GSX **
Discussion Starter · #3 ·
Actually I just got home with a new OBD II Diagnostic Tester... on my 95 GSX anyone know where to plug in the plug for the tester into the car? Thanx
dg talon here. if your engine check light is on and you disconnect the battery, and the lighy goes out only to come back on in a few days, change your feul filter. it maybe your problem. that was defintly mine. the dealer couldnt even find this one. they ran codes but nothing showed up. i put in new filter 6 mons. ago and light has never been on sense.its a cheap fix if it fixes your problem. good luck
1 - 6 of 6 Posts
