This started happening yesterday morning. The clutch engagement point was abnormally low to the floor, and the shifter was pretty stubborn getting into gear. After driving the car for 15 mins like this, it eventually got back to normal.
The car remained fine in the afternoon, but after starting it after it was in the cold night weather for a while, the same problem came up. This time it was even harder to shift, i had to force the shifter into gear with a lot of effort. When putting the car in reverse it would grind, and do the same getting back into gear, as if the clutch wasnt fully depressed.
The clutch tends to stick a bit halfway out, and fully release a bit slower, with the friction point quite low.
I was going to check the clutch slave and master cylinders for fluid today. Also maybe look into greasing the axle of the pedal assembly...I'm not sure if this would relate to my shifter problem though. Any other suggestions?
