1 - 5 of 5 Posts
I have a 95 gsx and the clutch wont fully release, when im in first gear and launch the car during 2 step the car creeps foward, also it is hard to shift. I have a new master cyl and slave cyl, its a spec stage 3 plus with the extended push rod in the slave cyl. clutch fork was not replaced, any thoughts or tips are welcomed
Try adjusting the peddle from actually behind the peddle, under the dash. I've never had to do this, but I've read quite a bit on this forum about it. If you can't figure it out by looking at your car, try searching for "clutch adjustment". Something like that should get you some great info.
Clutch fork could be bent just a little. I've seen a stock one bend right after an ACT 2600 was installed. Afterwards, the problem was pretty similiar to what your having.
1 - 5 of 5 Posts
