1 - 2 of 2 Posts
I'm swapping out my clutch for an RRE X-Clutch and will most likely need a new friction surface as per Mike said from RRE. I contacted Clutchmasters direct since they're only about 10 mins away from me but they want a damn $104 for a new friction surface!!!!! I've heard RRE sells the Fidanza ones cheaper. I've searched and found that Fidanza makes the clutchmasters aluminum flywheel and that it's just a "rebadged" fidanza. Anyone know or have any HARD evidence that they are the same? I just need to know because I'd like to know a vendor that has the damn friction surface for a bit cheaper than $104. Thanks all
i do not believe they are exactly alike the wiehgt on them are proly different because i have a fidanza and its 7.8 lbs and clutchmasters is proly a little diffeerent, if you buy it give a review for the item i got mine for 200 and thats cheap usually they are 240 so try it out
1 - 2 of 2 Posts
