1 - 7 of 7 Posts
If you've done a brake upgrade using the Ford Cobra rotors then you know that concentric hub rings are standard practice. However, this does not address the issue of the mounting holes on the rotor being much larger than the DSM studs.
It still is necessary to center the rotors on the hub using concentric hub rings but if you want to also eliminate the gap at the studs you will have to either re-drill the rotors, install larger studs, or simply use my kit. These sleeves are made of steel and fit precisely between the DSM studs and the Cobra rotors.
One kit takes care of both front rotors for just $25 shipped.
How-To Video
These still around?
1 - 7 of 7 Posts
