One of my not so computer literate friends had me post this. He has a 20g, 550's, and a spearco I/C. Sometimes he gets a little sputtering and wanted me to ask some other people with the same mods, about settings for responce and gain.
92 Talon AWD
Mods:
2.5" BR D.P. 2.5" Dynomax cat-back, 95 Manifold, BR upper I/C pipe, K&N, Extreme [email protected], Walbro pump, Apex AFC, ACT 2600.
Turn the response to 100% and the gain is a little more fuzzy. Every car is a little different, but on race fuel I'm at almost full lean. Its been so long since my car had pump gas so I don't remember for sure but it was like one or two points above 0.
Use a datalogger to tune at WOT for the correct gain. Look at O2 voltage and it should be above .85 at WOT. Tune for .85-.87 for max power and remember that setting for future reference.
I have 16g, FMIC, and 550s.
I have Response at 2 O'clock, and Gain at like 9 O'clock. Seems to run fine, except when I crept to over 20 psi, then I start to lean out. Hopefully my external will be on by the end of the weekend.
Turn the response all the way up. The VPC is already slow enough to respond to throttle commands, don't increase the problem.
