1 - 20 of 246 Posts
Started the tear down yesterday morning. Needless to say I'm excited to finally have the time to build her like I want and get her back on the road.
Parts list:
HEAD:
-Hot tanked
-Decked
-OEM 6T valves
-Kingley "street" beehive springs
-DKS 272 cams
BLOCK:
-Hot tanked
-Bore and hone .20 over
-Check deck and resurface
-Polish crank
-Balance rotating assembly
-Mahle low expansion pistons 8.5:1 .20 over
-Scat rods
-Tri-metal bearings
-OEM composite
-BSE kit
-OEM oil pump
-OEM gasket/seals throughout
-OEM oil pick up
DRIVETRAIN:
-4 bolt rear
MISC:
-Evo exhaust manifold
-Cyclone IM controlled with link
-ABS delete
-Manual steering rack
About to solo this engine pull, don't think it'll be this easy going back in.
On the engine stand now
Oh hello balance shaft belt, whatch doing over there?
Stripping her down
2 rockers popped out
Ouch!
After seeing how much carbon build up no wonder I wasn't able to get more then 10* peak timing at 26psi.
Well thats it for now, sat I'll be dropping the head and block off at the machine shop.
Discussion Starter #6
Thanks guys!
Looks like a good start. When the engine is going back in, see if you can find a Load Leveler for the engine hoist. It'll make life a lot easier doing it by yourself.
Do'h don't know why I didn't think of that, load leveler should make life much easier. Thanks!
Everything bagged up and marked.
Manual steering rack with correct brackets, just waiting for rebuild kit. DKS272 cams, custom hood struts, abs delete, and evo 3 manifold. Still waiting on a few more packages. :D
Discussion Starter #7
Progress so far today. I removed ABS, most of the power steering stuff minus the rack, all that crap on the fire wall, and cruise control. After that I installed the non ABS stuff and cleaned up the bay a little.
Pics:
Discussion Starter #9
All my parts finally came in.
Discussion Starter #11
Just picked up my head and block from bogusSVO, progress has been slow due to life but moving forward non the less. I'm about to order my bearings and hopefully if time allows I'll be assembling the long block this weekend.
Looks very nice! FWIW if you keep the dampner pulley and the main crank bolt out while removing/installing the engine you buy yourself alot more room and reduce the risk of scratching up the engine bay.
Discussion Starter #15
Starting the assembly today and now at a stand still because my machinist said my clearances are a tad tight for my goals after I plastigauged the mains. Front to back I got
(F) .0016 .0016 .0015 .0014 .0015 (B) So I'll be bring the crank to him on wed to have it polished a tad more. What do you guys think?
Pictures:
Discussion Starter #16
Lol at the dog
That's my very manly 10lb Yorkie :p
Thanks for the update! Looks like things are coming along.
No problem, its going a little slower then I'd like due to shit going on in my life. But non-the-less its coming together nicely.
Looks very nice! FWIW if you keep the dampener pulley and the main crank bolt out while removing/installing the engine you buy yourself alot more room and reduce the risk of scratching up the engine bay.
Thanks for the heads up, I think I might just do that. Depends on if I feel like putting the timing side together in the car. Wouldn't mind having room to work:)
You can put the timing stuff together outside the car. Just spin the bolt off before you drop it in and make sure to put it back on before starting it.
Discussion Starter #19
1 - 20 of 246 Posts
