Hi, guys.
My name is Amlie,and I am very glad to be here to introduce my business to you, and I hope I can have the opportunity to help you ,
We can offer you CNC Machining & Manufacturing Services,Rapid Prototype Machining Services 3-axis, 4-axis,3+2-axis CNC turning milling, turned- milled combined machining,
Injection mold ,3D printing, sheet metal fabrication, grinding,Laser Carving etc.
*Non-standard & custom mechanical parts(different material, such as aluminum, steel, brass etc)
*High precision CNC machining, lathe machining
*sheet metal processing and laser cutting
*shaft, gears, bolts and nuts, springs
*welding and assembly
*Aliuminum die casting and extrusion
Reliable and professional machining partner!
Pls feel free to send message.Engineer06ATtop-rp.cn
Best regards
Amlie
Best regards
Amlie
