JayHäss said:
Hemi is short for Hemisphere, as in half a sphere.
Back in the 60's where high technology was having more than one carburator, Chrysler made a head with the chamber shaped like half a sphere and spark plug in the middle. It's better for combustion and makes more power. It was the big technological "oooooooo" of the time.
Basically all DOHC cars now are hemi's but with 4 valves.
Just to add to the definition...
The big performance gain for a hemi design are the "canted" valves. A hemispherical combustion chamber allows for the valves to be tilted toward the air flow and allows for the intake / exhaust ports to be more straight going into the cylinder, which of course helps with air flow. In a none hemi design, the ports need to take harsh turns to lead into the cylinder.
Making HP is all about moving more air through the motor, so there are huge gains to be had with head design, so a hemi head w canted valves is the ultimate in head design.
Big block chevies were refered to as semi-hemis because the exhaust valves were canted, the intake valves were not canted as much to save space. Because of the canting, the head is much larger than a none-canted setup. That's the only draw back to a canted (hemi) design is the amount of space taken up by the head and it's increased weight.
I'm not sure if the center plug placement is necessitated by the larger head or just because it helps with performance. The plug location may just be needed because there is no other way to get them in the combustion chanber due to increased head size.
the 4g63 looks like a true hemi design to me. It's awesome to know I drive a turbo hemi!! even though it's only a 4 banger. When I grew up, it was the shit to own aything with a chrysler hemi. those were / are bad ass.
One thing I've noticed about the 420a in NA 2gs, the head is small, so I assume those valves are not canted (if so, not much), so the head probably doesn't flow as well as a 4g63.
