I need to manualy adjust my Deltagate II wastegate for minimum amount of boost - around 5 psi. Does anyone know the correct way to do this using the hex on the top?
well...mine is the one with teh 9-13 psi spring...with the hex fully out you do 9psi and fully in 13psi...that's mine...it has a #9 sticker at the top...if you want more you'll need a boost controller...
Thanks...mine has a #7 sticker on top...I'll assume that means 7psi minimum. Its actually not for my car...its for someone else that needs to still get a controller. I just don't want him to run high boost until he does some other upgrades.
