PREVENT TO FLAMMING. I have searched on DSMTalk and other forums and have found out tons bout a NT conversion. The questions below I have either not found the answer on or would like a little more clarification. Also this is going to be the first time tearing a block open but not taking a motor out (I have rebuilt my own tranny) so I am not mechanically incompetent.
Ok I recently came across a 6Bolt 4G63 NT. The motor was sitting on the ground for who knows how long with the throttle body and exhaust manifold off so the motor is going to be a full rebuild. This motor is going to go into my 95GSX (have the 6bolt awaiting for the dreaded CW) so I already have the exhaust manifold, turbo, injectors, ECU, knock sensor, MAS, pistons and motor mounts.
I know I will need rods (fly like an eagle), oil pan (for the oil return line), Cams and CAS. But what else will I need and is a NT block the same as a Turbo block? I was told that the NTs don't have "oil squirters" like s turbo has to squirt the bottom of the pistons to help in cooling. . . . this correct? Is the intake manifold the same on 1G T and NT? And last but not least is the internals in the head the same (like valves)?
