Dimmer switch not working
870 Views 1 Reply 2 Participants Last post by  firestarter4206
Like i said in the title my dimmer switch isnt working but my gauge and HVAC works. i do have reverse indiglo gauges tho maybe thats y my cluster lights and HVAC is still working. if i hit any bumps or hit my steering wheel the light flickers. so im not sure if its the fuse or not. i check the fuses under steering wheel everything seems fine. im not sure if there are any other fuses i should check? or is the dimmer switch broken? probably something EZ to fix but im not no electric pro.
1 - 2 of 2 Posts
the stock dimmer switch or the aftermarket one that comes with it?
if its aftermarket and not working check your ground
if its stock you cannot wire aftermarket gauges to this unless you have a wire to do so and it shold be purple? or orange then you can
1 - 2 of 2 Posts
