1 - 2 of 2 Posts
I have looked back and forth between all the diagrams and and webpages as far as installing my s-afc. I think I have it pretty much figured out but there are a few things that I am not sure about. On vfaq.com it shows the blue wire being connected as the 02 wire on pin #4 but in a supplementary wiring diagram that came from extreme motorsports (i guess) it says to connect the white wire to that same pin, but says nothing of the blue wire. I also already have an a/f gauge so do I need to connect it up to show in the s-afc display? i dont want to draw current if i dont have too.
Honorary Administrator
If you would like to monitor O2 voltage hook up the blue AFC wire to the O2 wire off of the ECU. If you don't need to monitor that through the AFC then don't hook anything up to the O2 wire.
1 - 2 of 2 Posts
