last nite i droped my oil pan in the process of removing my balance shafts (at first i was very intimidated by the timing belt/balance shaft vfaq, proud to say i took everything off from the upper t-belt cover to the rear balance shaft in 2 1/2 hours heh) and in the bottem of the oil pan i found sum small aluminum chips..all of them were flat shaped, niether side of the chips had a smooth finish..as in the chips were rough on both sides..what could this have been? parts of my pistons? what all is aluminum in the motor..the head..the pistons...the front cover??
my motor always ran real well...the bearings on the shafts and the bearings in tha block looked real good, never heard any weird noises or anythin..what do you guys think it may be??
