1 - 9 of 9 Posts
My name is James, I have rebuild about 10 to 15 throttle bodies as of right now and just thought I would see if you guys needed any of yours done. I have done turbo and non-turbo throttle bodies. Here is what is included with my services.
Full name:James LeTang
Paypal: [email protected]
Description of Services/good Offered:
Cleaned and bead blasted
Install new shaft seals (Real seals, not o-rings)
Install new Biss O-Ring
Install new Biss screw
Install new Isc O-Ring
Install new fiav O-Ring
Install new fiav screws
Use loctite
Tested to make sure there are no leaks
Typical Turnaround time: 2-3 days
Price. 70$ I will pay return shipping
Re: Dsm Throttle Bodies/Services
Can you do any painting, powder coating, or polishing to the throttle body's for an additional fee?
I was able to grab an 1g throttle body from the yard for 3$ so i want it redone before i use it but also want it shiny or blue.
Discussion Starter #4
Updated and some more pics. Lower price to 60$.
Installed new shaft seals (Real seals, not o-rings)
Installed new Biss O-Ring
Installed new Biss Screw
Installed new Isc O-Ring
Installed new Fiav O-Ring
Installed new Fiav Screws
Installed new Tps Bolts
Polished Throttle Plate
Used Loctite where needed
Wow very quality work and at a great price. I will be contacting ya when I find a NT TB. I really wish you could do polishing though because it's going to be mated to a very polished SMIM:(.
1 - 9 of 9 Posts
