I wired in the signal wire from the wideband(white wire) to the signal wire to the ecu coming from the rear o2 sensor (light green-black)....I set up the rear o2 as a the AEM WB on DsmLink....it has a reading but it does not match the reading from my WB gauge......the WB reads about 14-15AFR @ idle but the DsmLink reads like 11-12 AFR @ idle.....both readings vary so i don't know whats going on...am I doing something wrong?
That always happens. Try a different input or buy the dsmlink buffer.
