The ecu is behind the radio just remove the driverside kick panel and you will see it. The eprom chip is soldered in place, you will have to get the ecu socketed inorder for the dsmlink chip to be pressed in.
Have you been to the link website by anychance??shift_racer said:I am planning on getting DSMLink on my 95 Talon. My question is, if my ECU has a factory EPROM is it just a matter of popping out the old chip and popping in the new one or is it actually soldered onto the board?....
Thanks for the help
I'd say that would answer your question.Socket Service: If your ECU has not already been socketed by someone else, then you'll need to send us your ECU to have this work done. No DSM ECU comes from the factory with a socketed EPROM. So you'll *know* whether you've had it done before. If you don't know, then you haven't had it done. With this package, we'll socket the EPROM and install a DSMLink version in place of the factory EPROM. We'll then ship the factory EPROM back to you, unmodified, so that you can always revert back to factory mode if needed.
You are not serious are you?14.5 drift said:Installed the chip directly (no socket) now the ecu is making a burning smell. What should/can I do?
