the brakes are still on so its burning alotta gas to drive and i have work tonight(pizza driver)
Just an FYI:BLCKOUT92 said:i wouldnt drive it much, your gonna F*** up your drums and pads. i dont believe theres any "water" to deal with. your ebrake is a cable, theres nothing hydrolic about it. crawl under the car and there should be a cable coming out from the center consol. check to see if its kinked, cut, stuck, whatever. if theres nothing wrong check inside the car under the center consol where the lever is i think there is an adjustment there. you can loosin or tightin the cable there. if that doesnt work, take off the wheel and the drum housing and find out whats jamming in there. sux that its cold out, i hate doing that stuff in the freezn cold. good luck, hope u can make it to work.
If there is no tension when you pull the handle, then it isn't the switch.Briuah said:Did anyone address the issue that your parking brake switch may be stuck?
