I am trying to plumb my ext wastegate to my 2G ex manifold. I have chosen to plumb it on the collector of the manifold and I need to know if I need to remove the divider within the collector completely when I bore through from the top.
Isn't the point of the wastegate to flow exhaust gases AROUND the hot side of the turbo? If you force it back into the exhaust manifold, it will flow into the turbo. Am I just not understanding you or are you not understanding the wastegate?
I'm not sure we understand your question. You plan on running your external of off the exhaust manifold, correct? Most people mount exhaust manifold externals off of the #1 runner. IMO, an 02 elimator / mounted external is optimal.
