1 - 20 of 65 Posts
Prices include Paypal fees.
USED Dejon Tool 3" intake with K&N filter $45
NEW Wilson Mustang 75mm TB with Jackson Auto cable adapter and I had the Vacume tube welded shut. $250
NEW WAS MOUNTED modified by throttle body's.com NT throttle body ported and has new shaft seals has the FIAV blocked $135
NEW never used Driven Innovations Sheet Metal Intake manifold. This thing is a peace of art, only 10 made for 1G setup. 75mm TB opening. $699
USED Valve covers $35 each
USED 1g intake manifold taped for Map sensor $35
USED 1991 Talon MT trans Grinds 3rd like a champ Pick up only Belmar NJ $200
4 Bolt axles Make offer
1g MT transfer case mising that sleve at the end that goes around the shaft (see pic) make offer
1g rebuilt head with 4 thosand miles on it Make offer
1g 6 bolt bare block with crank good shape make offer
the head and block and crank are oiled and bagged
1990 oil filter housing with ported relief valve, Has provision for external oil cooler - $75
USED Tial 50mm BOV - Black - $170
USED 1g fuel sending unit with a 1993 210 lph denso rx7 tt pump - $90
NEW Fuelab 818 Series In-Line Fuel Filter - $80
NEW Bosh 044 fuel pump in tank with 8an fittings mounted on 1g Unit (was in my tank but never ran) - $215
DOES NOT COME WITH BOSH SOCK THE SOCK MAKES THE UNIT TO TALL FOR A 1G TANK
USED Jays Racing Alternator Relocation kit $90
JM Fab Coil Pack relocation bracket, 1g ONLY - $30
NEW EVO Mobile One oil cap $12
Custom boost leak tester y0! $30
USED OEM Mitsu EVO Factory cd player $50
USED Symborski Shifter Kit $30
DEFI D amber gauges ( Discontinued) Fuel pressure , Oil Pressure, Boost and EGT (Not willing to split) $450
http://www.egauges.com/Defi/light.jpg
they match a 1g amber cluster like stock
USED FIC 950cc Injectors $200
Re: Race car part out take a look
If you ever decide to split the boost gauge I will take it. I like that fuel filter, I have to think about it.
What size is the inlet and outlet?
I'd get the boost and egt if you split them up. Do all the gauges have the neccesary hardware to hook it up? Sensors and all that.
PM sent about valve cover.
I will take the JM Fab coil relocate kit. Can you post your Paypal addy please?
Thanks,
Jason
Discussion Starter · #11 ·
firebirdvert305 said:
PM Me for a price shipped for the 6 bolt block + crank...lemme know asap thanks man.
I dont even know how to go about shipping a block and crank to florida but if you find a way to ship it from nj to florida we can take it from there
1 - 20 of 65 Posts
