1 - 2 of 2 Posts
OK I have searched this topic and have read multiple threads for the past hour. When I start my 92 laser turbo up the car stalls, you have to hold your foot on the gas for a little bit befor it will idle on its own. Then as the car gets warmer the idle rises, usually peaks at about 2500 rpms. I just replaced the isc and tested it out plus the conections and everythings works, yet it didnt help my idle problem. I tried a new coolant temp sensor, nothing. I blocked off the egr and nothing. Could it be the FIAV? What I got from searching is that a bad FIAV will cause you to have high idle on start-up and the high idle will continue. Thats not what mine is doing exactly but is it possible for it to be stuck closed? I also got this car stock from an old guy so I don't think he would have messed around with the tb.
Usually the problem you are describing is caused from no FIAV at all, or possibly a blocked one. Have you tried setting the BISS?
1 - 2 of 2 Posts
