1 - 20 of 23 Posts
I'm just curious as to if anyone has had any experience with this. I'm in the process of looking for a turbo manifold and found this to be half the price of a dnp manifold. Has anyone had any experience with it? Also, it says it's superior to cast iron and shipping weight is 14 pounds, so i'm curious if it weighs more than a stock manifold. Thanks guys.
Got one on the 16g and on the 60-1. Love it!!!!!
For the smaller turbo, it's an even power band, rather then feeling slow then hitting the boost and push you back in your seat, it evens it out.
On the 60-1.. Just amazing! Def noticed a huge difference over the ported 2g mani. Spool time was improved!
My car trapped 116.5mph on a street night. With a heavily ported 2g manifold. A few weeks go by, same tune, FP manifold, and a rebuilt throttle body (original did not leak bad at all) and on in 84* weather the car trapped 118.5mph. I contribute the mph to the manifold mostly.... Helped me out. This was on a 16g.
WORLDS better than a DNP IMO. BEST Mitsu-style manifold out there, hands down.
Is there any information on a comparison between the two:
FP manifold vs. DNP?? I have a PTE5031e and would like to find the best manifold that have the biggest performance increase in spool up time.
I have one on my 97 GSX with a 6 bolt swap. I just finished building the motor and got it running. Changed so many things, can't attribute anything to or from the manifold, but it definately seems to flow well and it is very nicely made. My car made 434AWHP on pump gas and was very smooth.
their coatings it the only one that is considered a thermal barrier. It lays on roughly 10x thicker than other ceramic coatings. It comes white, but they say that it does so well with heat that you can paint over it. I painted this one a light gray with VHT 2000 degree manifold paint. So far it has only changed a little color by the collector because of the heat seen in that area of the manifold (as noted on other fp manifold that I have seen). As far as price, I paid $385 for the manifold, turbine housing, and 02 housing to be coated. A little pricey but given that there are no heat shield options that I care for for the FP manifold, I figured I would try this.
From the above said I wouldn't say then that it (the coating) does a superterrifik job. I used VHT 2000 on a bare (rusty) 2g manifold and the results were not much worse - some discoloration on the collector and a bit on the top of the runners. That paint is quite heat tolerant by itself.
1 - 20 of 23 Posts
