1 - 1 of 1 Posts
For Sale 1996 Eclipse GST Project Car.
This car was a daily driver and used to race it at LACR a long time back. It has been on a trickle charger in my garage for 15 years. I couldn’t let go of it because of all the time I spent under the hood, but its time to see if
someone is looking for a project car. This car is modified and will not pass smog as it does not have CARB approved parts. This car is sold as is. There is no warranty. It is currently registered as non-op.
In a nutshell…. Stock motor with FP Green, 40mm TIAL wastegate, 3” exhaust, Denso 660c injectors, Spearco 272 FMIC, ACT 2600 clutch, Ground Control suspension 500/350, and lots more.
Message me you offer or email me at [email protected]
Parts List
Thermal R&D 3” Catback Exhaust w/ 4” Tip
3" Flange
Weld on flange
Magnecor 8.5mm Plug Wire Set
NGK BPR7ES
Lo-Tek Engineering 3 Pod A-pillar
AutoMeter -30-0-30 PSI Boost Gauge Silver
AutoMeter Air/Fuel Gauge Silver
Silver Reverse Indiglo dash gauge
Larson Colored Hose Kit - Purple
More Hoses
HRC Eliminator Jr. 3" Downpipe
HRC 3" MaxFlow Cat
Greddy EGT 60mm Silver Elect.
Weld on fitting
Walbro 255lph Fuel Pump
Fuel Pump re-wire
Indiglo Needles
Apexi S-AFC 2nd Generation
Denso 660cc Injectors "pintle type"
B&M Short Shifter
Suspension Shifter Bushings
OEM Lifters
VC Gasket
Spark Plug Gasket (4)
Cam Shaft Seal
Oil Cap w/ Gasket
FP Green
40mm Tial Wastegate
Evolution3 Exhaust Manifold
Port mani
Gasket Factory 7cm Exh. Manifold
Gasket paper drain (2)
Gasket Exhaust Mani to Head
Gasket, O2 Housing
SS Oil feed line 4G63
shipping
O2 Housing - 2G 2.5" SS
Tial 40mm wastegate inlet flange
Tial 40mm wastegate outlet flange
shipping
Dejon Tool 3" Intake (CIP-2gC w/ CC & VCV tubes)
shipping
Spearco 2-272 FMIC
2.5" Mandrel bend pipes and gaskets
Catch Can
Injector o-rings lower
Greddy EGT fitting
Bomex front bumper
Greddy Profec B
Fluidyne Radiator
Mach V Leak Tester
Greddy EGT Probe
Greddy EGT Probe Fitting
TB Gasket
3" Tbolt Clamp
40mm Tial Wastegate lower housing
40mm Tial Wastegate diaphram
Black Racing 18x8 +38 w/ Toyo Proxies
TurboXS H34 BOV
2G Adapter kit
ACT 2600 (MB-010X PP / MBSD010S disk / TB)
Aluminum Flywheel
Stainless Steel Clutch lines
ProfecB Remote Switch
Ground Control Coilovers (8" 500f / 7" 350r)
Front Upper Mounts
Koni Yellows
2 1/2" Hump Hose
2 1/2" Silicone Coupling (1ft.)
15ft 6mm Silicone Hose Black
3" Hose Clamps (2)
13" SPAL Fan (1710 CFM)
Fan Radiator Mounting Kit
Cooling Fan Harness w/ Relay
shipping JayCorp Technologies $21.00
10" SPAL Fan (1070 CFM)
Pivot FCG Digital Coolant Temp
15 ft Silicone Vacuum Hose 4MM Black
10 ft Silicone Vacuum Hose 6MM Black
6 ft Silicone Vacuum Hose 8MM Black
OEM 97-99 Front Bumper Cover
97-99 OEM Headlights
1x 2.5" Silicone Hump Hose, Black (SIL000015)
5 x 2.5" Silicone Hump Hose, Black (SIL000015)
Triple Pod
1 - 1 of 1 Posts
