1 - 20 of 40 Posts
___
Description:
The time has come to sell my baby. I've owned this car now for 6 years and it's time for a change. The reason I'm selling is because I bought a Lexus and I need to pay it off.
1997 Eagle Talon TSi AWD
  • 134,XXX Miles
  • 5-Speed
  • Cruise Control
  • Power Steering (Very smooth, newly installed oem pump and new rack & pinion)
  • A/C Included* Installed but needs recharge.
  • Leather Interior (Gray)
  • Sunroof (Works great!)
  • Rear defrost /Wiper (Works great!)
Drivetrain Mods:
  • Freshly rebuilt stock transmission
  • ACT 2900 / Stock flywheel (Freshly machined)
  • SS braided clutch line
  • New OEM Mitsu master clutch cylinder (recently replaced)
  • Recently replaced clutch slave cylinder
  • B&M Short Shifter (set at 50% throw reduction)
  • Skateboard bearing mod for shifter linkage (tightens slack in shifter assembly)
Engine:
  • Stock 7-bolt (Never been rebuilt, can still see cross hatching on cyl walls
  • ARP Head studs
  • *New fresh oem composite head gasket
  • 1g Head swap (1g shaved emblem intake manifold/ 1g throttle body/ 2g Throttle body elbow/ fresh valve seals included / New oil cap).
  • Shaved Valve cover
Turbo / 3” Exhaust:
  • 2g exhaust manifold / t25 / 2g o2 housing
  • 3” SS Megan Downpipe
  • New 3” custom cat-back (No Cat, SS magnaflow 4” round muffler welded after downpipe)
  • 3” inlet OBX “Apexi” replica polished SS end-muffler (Looks really good, almost identical)
  • Cat-back bolts to down-pipe
  • I can include the stock end muffler, and a straight pipe to bypass the end muffler
  • Custom 3” intake w/ filter
Intercooler Setup:
  • Spearco 2-216 AGP RACE core ( 28x10.5x3.5 not including end tanks)
  • Polished end tanks
  • 2.5” piping (t-bolt & silicone couplers)
  • 1g eclipse turbo blow off valve
Fuel:
  • Walboro 255HP fuel pump (re-wired 8ga)
  • -6AN black SS braided passenger side fuel line setup (w/ Earls in-line fuel filter and fuel rail adapter) No stock fuel filter.
  • Stock 450’s (Brand new OEM injector seals and insulators)
  • Stock FPR and return line
Audio:
  • Alpine CDA- 7893 FM/AM CD-player w/ Bass engine / 3 pre-amp outputs & subwoofer control / XM ready
  • Infinity 6.5” component speakers up front
  • Clif Designs 6x9” rear speakers
Other Mods
  • Drivers side Slim Fan
  • New (95 AMP) Saturn Alternator swap (This is a new mod guys are doing to get rid of the sketchy regulators in our stock alternators, and bump the amperage up from 75.)
  • Clifford Matrix RS2 Alarm system
  • Headlight shroud’s have been painted gloss black
  • Emissions have been pulled, all unnecessary vacuum lines capped. This makes finding a boost leak a lot easier.
Suspension:
  • Apexi World Sport Street Dampeners (Coil-overs)
  • Sprint or ingalls (I forget) camber kit
  • Polished strut bars, front and rear
Wheels / Tires:
  • Flat Black Rota Subzeros (17x7.5 +42 if I recall)
  • 1 year old BF Goodridge G-Force KDW new treads all around
New Stuff
  • New Optima Red top battery
  • New OEM Power Steering Pump
  • New Accessory Belts
  • New SS exhaust studs/nuts/washers
  • NEW VIS Carbon Fiber OEM “style” hood
  • NEW Aerocatch flush (black) hood latches
  • New March 2009 inspection
  • New freshly changed oil/ filter/ Coolant/ brake fluid/ and power steering fluid.
  • Always used Mobil 1 Synthetic 10w-30
  • New Front brake pads
__
__
More pics of the exterior / interior / and engine bay to come...
****EDIT 7/2/08: I will be leaving for vacation this weekend and I won't be able to show the car until July 13th. Unless you want to come see the car within the next 2 days.
Discussion Starter · #2 ·
Discussion Starter · #3 ·
Discussion Starter · #4 ·
Discussion Starter · #5 ·
Discussion Starter · #6 ·
Discussion Starter · #7 ·
Just did a compression test:
Starting from 1 - 4 in that order:
Cyl 1: 157ish (it's inbetween 155 and 160)
Cyl 2: 155psi
Cyl 3: 160psi
Cyl 4: 160psi
Discussion Starter · #8 ·
The car originally had a 2.3L built stroker. I decided to remove that to sell and re-install my 7-bolt that I pulled out when it was still running. Here are some pics of the recent work to prove the parts and how nice it really is.
ACT 2900 and resurfaced flywheel:
1g Head: This pic was taken when I first pulled it out, you can see how clean it the head is and how often I changed the oil. My 2g head had a brown tint to the walls. Also I forgot to add that the intake manifold was gasket matched which helps flow a bit.
Discussion Starter · #9 ·
The block: I cleaned everything including the tops of the pistons real good.
New OEM composite headgasket:
Copper Gasket spray to help seal :D:
Discussion Starter · #10 ·
Cleaned everything and painted it flat black on a pallet:
New brake pads :cool: :
Discussion Starter · #11 ·
Ugh, dude, she's beautiful! Don't let EE see her, he'll blow his load.
Damn, this is such a good deal. :(
I saw this already, I was the first to look at it.. I have been biting my tongue.
He also has it posted on the Link Forums.
Got Insulin? said:
Lol. Is it weird that you were the first thing I thought of after I saw it?
Yeah it is, I figured that memorable night we spent on bareback mountain would have been the first thing you thought of, this car the second :D
:naughty:
Discussion Starter · #17 ·
Uhhh buy the car and I'll ignore that comment :p .
Wish I could bro, wish I could.
Too many cars and not enough job right now heh.
Wow. If my T/A sold and I hadn't picked up this 1g AWD shell to gutswap, I would seriously 100% buy that. It's exactly what I was looking for and in the price range.
FAWk :(
Best of luck!
1 - 20 of 40 Posts
