1 - 2 of 2 Posts
6 bolt- Pauter Rods, Wiseco Pistons, ACL bearings, the block itself was fully balanced, BS delete, brand new Fluidampr damper, OEM main bolts, OEM Crankshaft Rear Oil Seal Case, OEM Rear Main Seal , OEM Rear Main Gasket, OEM Crankshaft Timing Trigger Plate,OEM Oil Pump Front Case ,OEM Oil Pump Drive Gear ,OEM Oil Pump Driven Gear ,OEM Timing Belt Tensioner Adjuster ...the works. I have ALL receipts brand new from extremepsi totaling well over $2,000 in just parts. Also have receipts of machine work & a couple people on the board can vouch for the motor being built 100% correctly, GaStroker welcome to chime in. This block has maybe 7 miles on it. I have come to a financial situation and have to get rid of my baby. I have a full partout going on but figured I'd give the local guys in Georgia a chance at everything before I post up here.
$1,500.
1 - 2 of 2 Posts
