Fs: EVERYTHING! Big Moving Sale!
2656 Views 56 Replies 30 Participants Last post by  dsm614
Liquidating my entire stock!, Last time we moved I got a big trailer and filled it all the way to the top, alot of people were pissed I didn't sell them shit so now it's round two...
I have a used 6 bolt block that in great shape and ready to rock and roll in your race car. $50 bucks.
Crank in great shape for $150, or block and crank for $200.
Brand new 4g63 stock pistons/reconditioned big rods, im not using them now, put them in the block above and have a rebuilt 6 bolt for next season.
Also, I have a set of dual piston calipers with brackets ready to upgrade your single piston/ FWD car's. $60 bucks.
FWD brake pad's, brand new, $20
New acdelco oil filter, $5 (I dont know why I have this??)
10 nakomoto valve stem seals, $10
Stock 1G intake tubes, 2 of them, 5 bucks each.
Front motor mount bracket, shaved for ARP Head stud's, $10 (allows you to remove head without taking bracket off)
1G throttle body elbow, $5
1G intake manifold, cleaned and silver, $15 (2G upgrade)
2 Stock 1G intake manifolds with EGR, $10 (can have these powdered for you also) 2G upgrade.
2G K&N filter/adapter (fipk kit), need's recharged. $10 (Sell for over $45 new)
1G thermostat water outlet, 5 bucks.
90' Power transister, $10
1G 14B oil feed tube, $10
ABS Box, 92 AWD $10 (this is under your hood)
Front and back water bottles, 92 AWD, $10
1G door handle, passenger. $5.
1.8 idle speed control servo, $5
92 AWD fuse panel, (under dash) $10
1G lower timing belt cover, alright shape, $10
Top timing cover, $5
2.0 NT 240cc injectors (set of 8)(1 set Hyundai), $10 (8 injector set-up anyone?
2 1G door switch, for the light's. $5
2 Stock 1G BCS, $5 Each.
1G Oil dipstick and tube, $5
3 6AN braided lines, 1 has banjo end's, (can use for oil feed) and 2 with femal 6AN ends. $10 for all (also have some little lines you can use for something)
2 90 TPS, $20 each
Multiple 91 TPS (3 prong) $20 each
92-94 talon bra, says "TALON" on hood section. $10
Multiple valve covers, I got whatever you need, every style. Best offers.
FREE....
7 bolt oil pickup tube. free
2 EGR's, free.
water pump pullys, free
2 Crank sprocket's, free
blue timing adjuster, free (80k)
2 timing idler pulley's, free
oil caps out the wazoo, free
oil pump driven gear, free.
TB braket (pulling engine) free
Rear 1G AWD motor mount bracket, free.
1G Front motor mount/powersteering bracket, free.
What I think is a 7 Bolt rear main seal bracket, free.
1G A/C fuse box, on the firewall. free
2 1G shift boot's, Free.
Dejon 90 deg bend, one side is cut, free
1G interior knobs. free
1G HVAC gauges, free
Slave cylinder rod, free
6 stock lash adjusters. (lifters) free
91 laser owners manual, free
6 bolt FWD flywheel, rusty and needs redone. free
This is all the shit in my basement, I haven't even touched the garage and the attic...sheesh.
More updates very soon.
1 - 20 of 57 Posts
Whatcha want for the (2) door switches, (2) brake callipers, (1) and that slave rod, shipped to 54956??
Thanks, Sam.
is the k&n filter and adapter both $10 total?.. how much for shipping to 75081(N.Dallas TX) also is the adapter metal or plastic?
Im interested in the dual piston caliper setup as well. Lemme know what happens with gvr4dsmer
PM's to gvr4dsmer & bobby98gst sent on items.
MindBlowin03-I'll let you know.
Also have some GM MAF's for sale $45 each + $10 to ship anywhere in the US.
how much for the steel braided -6an lines to 06457 CT
I sent you a PM...thanks
Pictures, please?
do you still have the 6-bolt block?
I would like to get these baby's from you! How much for shipping to 78744?
Interested in the EGR. Are they new and what year do they fit. I have a 2G California car (Have to have one or sets a code) Also the oil caps are they new or used. Interested in getting those.
Happen to have a eprom ecu?
I'm interested in the FWD 6bolt flywheel...any pics?
Pending PU now...sold
PMed with price
No sorry
Everything is used. The EGR is from a 1g. Oil caps in good condition.
I will get you a pic
do you have bov return tube?
do u have a 1g drivers side door handle?? lemme know, thanks! send pics to [email protected]
No, i dont have one of those... sorry.
I can get one for you, but I dont currently have one.
you have1g turbobck exhaust? or hard uip?
1 - 20 of 57 Posts
