1 - 9 of 9 Posts
I have a 97/98 GSX A/C Compressor I bought from a member here
and said it works perfectly...
I gave up on trying to fix my a/c so I have this for sale!!!!
If interested I will get a picture!
I know this is a F/S thread, not a tech or help thing, but have you went through every thing else to determine if it might be a combination of things as opposed to just finding one thing thats wrong.
tarantula wrote,
The compressors are the same, what is different is the mounting. I have a 95 block and a 98 block. I used the 98 compressor on the 95 block and it would not bolt up... What I found is the mounting bracket is slightly different. So dependant on the block you use, you have to use the bracket according to the year of the car.
So to give you an example, In order to use my 98 compressor setup with my 95 engine, I had to use the 98 bracket on the 95 engine block.
Discussion Starter · #4 ·
omg... Here some pictures to prove it...
I would have to buy new Compressor Lines because THEY ARE different.
On top of that the entire freaking Compressor IS different....
Maybe its another 95 thing, 95 is jus fked...
Here is the same picture twice,
Discussion Starter · #7 ·
Bump! This thing is still for sale!!!!!!!!!!!!!!!!!!!!!
Discussion Starter · #8 ·
No one needs A/C durring this summer heat!!!!!!!????????
Discussion Starter · #9 ·
No one wants a/c durring this hot summer!
This is your chance you get fresh!!!
1 - 9 of 9 Posts
