1 - 15 of 15 Posts
I've been battling high idc's so today i checked my fp to see if it was raising 1:1. My first test at 42psi bfp i applied 20psi to the afpr and as expected fp raised to 62psi. I upped the boost source to 25psi and got 66psi fp but no matter how much more boost pressure i added to the afpr it would not raise fp over 66psi. I also tried 45psi bfp and added 25psi to the afpr and got the same 66psi fp. Its a brand new aeromotive afpr. I am also running a rewired walbro 255. Shouldn't the walbro be able to push that much fp under that much boost? I pinched off the return line for a moment and even then i only saw 68-70psi fp. Last summer i replaced the seal on the pump where it meets the sending unit.
I've been battling high idc's (90%) on 650's 2g maf fmic and a s16g at 20psi on 93 octane and was hoping this was the culprit but after seeing the afpr raise the fp accurately up to around 23psi i don't think this is the problem.
I'm looking for any ideas on what might be going on or somethings to look into.
Thanks
On idle if you raise the fuel pressure, does it stop at a certain psi?
I had a similar problem last year, it wouldnt raise above 35psi (vac off) , and was hitting fuel cut every time. Finally found i was missing the plastic spacer which goes in between the pump and fuel line.
Discussion Starter · #3 ·
It was able to hold 50psi base fp without a problem. I am sure that the plastic spacer seal and cap are on the walbro correctly as well.
Discussion Starter · #5 ·
Are you sure that those are 650cc injectors? just a thought!
Boost Leak test wont hurt at your situation right now, so do that as well.
I boost leak tested to 30psi after the fmic install last week with one tiny leak. It takes close to a minute for the boost to leak down to 10psi.
SmokinV8's said:
Already checked that. Besides the pump could only muster up 70psi even when i pinched the return line.
The fuel pump could only throw 70psi?? A wally 255 should be able to throw more than that!!
Discussion Starter · #9 ·
Thats exactly what i was thinking. I just want to be sure its shot before i buy a new one.
Discussion Starter · #11 ·
Fix that boost leak.Does your fuel pressure drop on 20+psi boost or stays the same?
i'm not sure i understand your question but when i applied 20psi to the regulator at 42psi bfp the fuel pressure raised 1:1 to 62psi and held fine it was when i applied 25+psi i couldn't get anything over 66psi of fp with the same 42psi bfp. I even upped the bfp to 45psi and applied the same 25psi to the regulator and it only raised up to 66psi again.
I meant at 20psi boost and 42 base pressure, Your fuel pressure should be 62psi.
Hook up a fuel pressure gauge to the Afpr and place it where you can see from in the car & do WOT pulls. I would prefer 3rd gear. The fuel pressure should stay at 62psi through out the RPM.
Discussion Starter · #13 · (Edited)
How would that be any different than testing it with 20psi from a compressor to the vacuum port while running the fuel pump off the battery? I'd assume with the injectors firing while it was running would play with fp a bit.? I did it that way and it held 62psi fp under the 20psi i feed to it at 42psi bfp. I have thought about trying that but I just don't like the idea of running a fuel line inside the cabin or anywhere outside the engine bay. besides i am more concerned why my wally 255 can't produce more than 70psi of pressure.
The test will tell you if your are loosing fuel pressure up top end. A defective fuel pump would do that. Telling you this from my own experience.
Discussion Starter · #15 · (Edited)
Well i have sort of an update
I did some more testing today and using a c-clamp on the return line i saw 80psi on my fp gauge before i opened it back up quickly. I don't even think i fully closed the line yet either. I fired up the compressor and applied 30psi to the regulator at 42psi bfp and again only saw 66psi. I had an old fp gauge lying around that i swapped out just to see if i could rule that out and sure enough without changing anything but the gauge my bfp jumped from 42psi to 50psi. I set my bfp back down to 42psi and applied 30psi to the regulator and guess what? I saw 72psi fp. It held the 1:1 ratio up to 35psi on the that gauge.
I guess its kinda good news the regulator and fuel pump are working right but it leaves my idc issue even more confusing now seeing i was running 50psi bfp and still seeing 90-93% idc's. They'll probly be close if not over 100% now at a true 42psi bfp.:confused:
1 - 15 of 15 Posts
