What does the selenoid do that connects in the vac. line between the fuel pressure reg and the intake. Just curios,mine was leaking so I just bypassed it, had no problems yet and it weird to have 20inhg at idle again.
Jonny
Got BOOST? Does a car good.
it is used for hot starts. what it does is cut the Vac signal so that the FPR sees 0 and keeps fuel up till a high Vac is seen ( some RPM's Over stock ) this is it. It is said to help hot start by adding fuel but I have not seen any down sides of removing this ( by passing it )
Bill Marino
HSP! :D
Discussion Starter · #3 ·
Thanks, I actually noticed it starts easier now with it removed and once it starts it doesn't smell like a gas station. Idles great too. As for the hot start I have had a few problems, like if i turn the car off and try to start it 15 minutes later, it starts and idles like I have a set of race cams in it with a huge loping to it. This stops once I start driving the car.
Jonny
