FULL suspension..?
647 Views 6 Replies 5 Participants Last post by  dyablo
well i want to eventually do my FULL suspension, like bringing all my stuff to new, i was going to go with the shocks..lowered springs.. then what struts and sways and etc. what parts would i need to upgrade ALL my suspension, beacuse i know mine is pretty bad... i remember a mechanic saying i had some .. something leaking.. and that was a while ago , so i really should change all my suspension, thanks just wanting to know what parts are involved in a full suspension change, or upgrade thanks
1 - 7 of 7 Posts
whats probably leaking is the fluid inside your struts...they go bad the seals crack and they start to leak. Now when you say a full suspension setup...well the simple suspension setup is just new struts/shocks and new springs. Now to change the whole suspension system means replacing all of the mounting points and hardware...top caps, cups, tie rod ends, wheel bearings, stuff of that nature etc... Basically anything that is involved with your suspension system that moves would need to get fixed. If your going to go all out I would also replace all the bushings too. Now for strut bars and such, those are aftermarket add ons that make your chassis stiffer and reduce body roll thus making the car handle better and become more responsive...those pieces are best left to personal preference and style. But pricewise all this stuff replaced brand new at the cheapest...KYB GR-2's and stock springs...should be about 500 all told...at the most expensive...can run you in excess of 4-5k for a very very good suspension setup that is tuned properly.
i just wnat a drop, stiff suspension and ya.. that is whats leaking on my car.. the strut he said.. so i need that changed too, so 1.7 drop .. adjustable shocks, unless there are non adjustable that are stiff, then strut, and strut towers, and sways? im not sure, i want REALLY good handling tho and less body roll definately..
If you want a drop, go with the eibach prokit. These cars do not like to be lowered a whole lot unless you go with coil overs. If You do lower DO NOT FORGET ADJ CAMBER KIT+ BUMP STOPS. If your on a budget, the kyb agx is a great choice because they are adj, unlike gr2. A common setup is the eibach/agx setup you could this for about 500.
even with those shocks u can mke it stiff so u dun bottom out right? (bottom out as much :-X)
what do you mean bump stops??? im doing an agx setup up w/ eibach pro kit do i still need bump stops???
quick question relating to suspension. On a sportlines/agx combo you still leave the bumbstops there but you just cut them in half right?
1 - 7 of 7 Posts
