I bought a 92 talon tsi with a couple bent valves, and had it fixed. I had the head ported, new valves and valve stem seals installed, and put on a ported 2g exhaust manifold because my original one was cracked. I had someone else put the head back on for me, because i don't know how to do cam timing and valve adjustments and such. I also had them replace the timing belts and all the tensioners. I've got the car running but it's bucket ass slow. When i finally put in my boost gauge i realized that i'm barely pulling any boost, if any at all. If i go to WOT in first i usually see between 0-2 psi. The very most i've seen was 5psi at the top of second gear. I've already pressurized the intake and found and fixed one leak, but that didn't fix it. I tried another wastegate actuator, no luck. I tried using an aftermarket boost controller and bypassing the stock setup, but that didn't work either. I also used someone elses stock boost controller and hooked that back up, to no avail. I took the intake hose off of my turbo and i don't seem to have any shaft wobble and the turbo spins freely. I also took the hose off of my blowoff valve, and it seemed to pass a bit of air during idle, but i've been told this is normal, and it passed less under throttle, granted this was while the car was in neutral in my garage, i didn't drive it like that. I'm running out of ideas here, and i could use some suggestions, cause it's no fun having a turbo car without the boost. The best thing that i've heard but not tried yet is that i could have possibly damaged my turbine wheel somehow with excessive heat. I did notice that my cracked stock manifold had a chunk out of it, and i suppose it could have possibly gone through the turbo. Sorry to make this so long, but if the turbo is my problem what rebuilding options do i have? Where can i get a turbine wheel, and can i replace the bushings? Will other turbine wheels fit in there and work better? thanks for listening and for any suggestions you can offer.
Maybe it's not the turbo. Perhaps the guy that did your t-belt and vlave timing has it off a tooth or 2?
What's idle vac at? should be around 19in.hg and steady, if not, it could be a cam timing problem.
I'm only pulling about 12in of vac at idle, which is what originally led me to believe there was an air leak in the intake somewhere. I did a compression test and the #1 cyllinder is a little low, but i didn't think it'd throw things off that far. What is the easiest way to check my cam timing? by lining up the gears? As i said i'm not familiar with those things, but i wouldn't put it past that mechanic to have messed it up either.
Same problem as mine
Your no boost problem seems so much like the problem I am having...expect mine makes a very anoying wisling..metallic sound after I try to boost.....I really think its the turbo thats dead....am getting a replacement soon.....I will let you know....but let me know if you found the problem...
Denny
1990 eagle talon tsi fwd
*turboless sucks....*
