Are you sure you did the wiring job correctly? Have you tried a 91 ECU? There were quite a few difference in the motor set up on the 90's vs the 91's.
It's not the isc i believe. This is the site you need: www.plymouthlaser.com/tps.htmlaxdudeee said:go to www.vfaq.com and it tells you how to adjust the ISC. You should be able to loosen the 2 bolts holding it onto the throttle body and movie it to either side and hook an ohm meter to 2 of the connectors (i forget, check vfaq) and it should be a certain value.
meant TPS my bad, mind going to fastMegaGS said:It's not the isc i believe. This is the site you need: www.plymouthlaser.com/tps.htm
