1 - 7 of 7 Posts
My 99 gsx is hard to start when cold like injectors are bleading down. also after driving 30 min and letting set of 30 min starts and runs rough and will stall and not want to restart has 550 injectors walb fuel pump and adj fuel press reg.
what are you using for fuel control of those 550cc injectors? Could be an adjustment problem. Any noticeable fuel leaks or smell?
Discussion Starter · #3 ·
i have an apexi safc2 no fuel leaks and no smells. i bought car with all the fuel upgrades on it. i don't think the safc is tuned properly. the sparkplugs are real black and it gets black all over back of the car.
It shouldn't be hard to tune that car, 550's and an e316g isn't horribly large or anything. The coolant temp sensor wouldn't throw a CEL, would it? If its not the sensor, do a boost leak test. Maybe a few small ones in old, dry vacuum hoses...if you haven't capped them already. When the hoses heat and expand, they could close the leaks just enough to not really notice them, you know? Just some thoughts....
1 - 7 of 7 Posts
