ok, i will be doing my hg this week with a friend of mine and i want to clear things up before we tear shit up. when replacing the hg, is it a bad idea to do the zip tie method or what. i really dont want to get so involved with the tbelt honestly. the belt is brand f'in new as of 1 month ago when it was replaced with the b-belt and all the pulleys and tensioner.
according to what ive found to do the zip tie thing i adjust cylinder 1 to tdc by cranking the crank to where the cams dowels are vertical and the timing lines line up horizontally, then zip tie the belt to the cam gears, loosen the tensioner, remove the sprockets and hang them with a clothes hanger, do the head then replace the cams and re adjust the tesioner. that sound about right?
i just want to know if its a good i dea to do or not since i really dont want to get into readjusting the entire belt which makes the process that much more involved.
any help would be appreciated.
thanx
luigi
thanx
luigi
