1 - 10 of 10 Posts
Im putting 2g .5mm overbore pistons in my 91. My question is, do I have to get a .5mm over headgasket, or is a stock size one a little larger than the bore to begin with?
Also, is the stock bore the same on a 1g and a 2G?
-Dave
I've never heard of over size head gaskets, anyone else??? I don't think you would need one anyway, the piston only comes to the top of the block and the gasket is already slightly larger than the bore.
Chris Holmes
'91 Plymouth Laser RS Turbo
www.geocities.com/motorcity/speedway/5051
Turbo + Intercooler = The Replacement For Displacement
You shouldn't have to worry about it unless you put the gasket on and it's hangin' out over the cylinder bore. If it's not, slap it on and forget about it. A .5mm overbore is 1/2 the thickness of a paperclip, and you divide that by 1/2 to get how far out the cylinder moved when overbored. Unlikely to be in to the gasket.
Scott
DIG through the ditches, and BURN through the witches, and SLAM in the back o' ma' DRAGU-LA-AA!
correct me if i'm wrong but are'nt copper headgaskets the way to go. i've heard that they are harder to blow than regular gaskets. and summit racing sells them for the 2.0 mitsu engine.
mike
the copper head gaskets that summit sells are i believe SCE head gaskets and they are just completly flat, meaning you have to have your head "o" ringed for it to seal. without the o-ring process it will not seal at all, i made the mistake and bought on for my turbo civic and it was definitly a no go, would leak with no boost at all (9.4:1 compression).
bill
95 tsi-awd
91 tsi-fwd
95 civic turbo
82 gti
Correct. The "dead soft" copper gaskets they sell DEFINITELY must be used with an "O"-ring. The head and block have to be machined, and the "O"-rings are Stainless wire, about .060" thick. Basically, a circular groove has to be cut in each mating surface. These are designed for like 30 psi boost and up.
Scott
ive had the SCE copper head gasket and its crap. every place that could leak did. i ended up trashing it and putting in a fellpro. works fine now
This may or may not mean anything to any one, but when i was putting my engine back together i asked Tym at Buschur if he recomended an aftermarket headgasket. He said to forget about it, that the stock headgaskets were the only way to go.
I heard from a well respected DSM owner that the best thing to do is torque the head higher than factory spec with a factory head gasket. Sounds good to me!
Jesse
99 GSX
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>
the best thing to do is torque the head higher than factory spec <HR></BLOCKQUOTE>
I'm not sure how good of an idea this is. I'm sure you could get away with a small amount of extra torque, but too much could do damage.
one thing is for certain, you should always use arp head studs any time you put your head back on. The stock ones will stretch, especially if you reuse them. And if you put extra torque on them they will certainly stretch even more.
1 - 10 of 10 Posts
