Hi im new to dsmtalk and i have some questions. My 99 eclipse gsx spun the balancing shaft bearing. Not the balancing shaft connected to the oil pump but the one that is run by a seperate belt. I need to know if there is anyway i can eliminate just the front shaft temporarily until i have the time and money to pull the motor and replace it. If i just removed the belt would it cause any problems to leave it in the motor?
Research a bit and you would know. Honestly in my 1g AWD the balance shaft removal was pretty simple and straight forward. My friend has a 2g GS-T and he just removed the belt and gear and put a bolt in the hole and called it good.
If it were me and I had the timing belt off, I would totally spend the 40-50 dollars for the removal kit and go through with it.
Pro's- less revolving mass in the motor, a lil more oil pressure, and mainly the relief knowing that damn bs belt won't break and kill the timing belt.
Con's- a lil more vibration in the interior(its not bad, almost not even noticable), gotta get your hands dirty.
