WHEEL BEARING. You sain that you used a 2g axle in a 1g car. Did you torq the axle nut. Sounds like you need to get a 1g axle, a new wheel bearing, and torq it correctly.
it has a 2g tranny. The 1g axle wouldnt fit at all. Are the 95-96 axles longer then the 97-98? about by an inch or so? because that would help alotdsmbuilder said:WHEEL BEARING. You sain that you used a 2g axle in a 1g car. Did you torq the axle nut. Sounds like you need to get a 1g axle, a new wheel bearing, and torq it correctly.
