1 - 6 of 6 Posts
my 95 gsx has been running good 15psi 20 g turbo, i put a different head on it 100miles ago. ran excellent . had 18p on vac. now it has 12 and i hear a hissing around the intake . as i get on it the hissing gets loud then my turbo flutters ,i back offand then the bov releases whats left . my bov stem wasnt seating good but i fixed that . my guess is the intake gasket , i had to use a 1g gasket and my head is ;nt ported to match it. thanks guys
I think he said so, but it doesn't seem to clear.
Check the vacuum hoses on the throttle body, check for boost leaks in your upper IC piping, check TB gasket, bla bla bla. I think there are more than a few things that could be "hissing" in that area...
What do you mean by "the turbo *flutters*"???
15psi on a 20g doesn't seem like much boost for that turbo....maybe you've got a boost leak that your turbo can make up for at the lower boost pressure...?
Discussion Starter · #5 ·
well i checked it out and found i believe the leak, my fpr arp brand had a loose allen bolt on the front where a pressure gauge goes. im putting a new tb and tbtensioner on it today because my belt keeps getting loose between the intake and oil sprocket my tensioner has 130.000 mile on it so do you think thats the cause? thanks :)
That would be a decent place to start, esp with that many miles....have you price checked at all? If you can find one cheapER, go ahead and replace it...
1 - 6 of 6 Posts
