And just to explain the inconsistant boost levels a bit more, this is what happens:
1st- Spikes to 21-22psi, then down to 16psi, then right before its time to shift, 17psi.
2nd- Spikes to 21 psi, then down to 19psi, then at exactly 5000rpm it drops to 17psi.
3rd- Spikes to 20psi, then down to 19psi, then at exactly 5000rpm, its drops to 17-18psi.
4th(OD)- Spikes to 21, then down to 19.5 psi, until 5000rpm, then it drops to 18psi.
I have been trying to figure this out for a long time. Keep in mind that there is no boost leaks, I tested it to 30psi.
