1 - 7 of 7 Posts
Hi,
I have received a pair of HKS camshafts from fellow dsmers, just wondering if they are real or not. Are the engraved marks correct? Are they 272s?
cams have engraved HKS on them.
one cam has A05-M 005 on it, the other has A05-M 006 on it. Are they 272s?
I looked these 2 codes on dsmtalk or web, can't find anythign.
Thanks,
Andrew
AWDx4G63 said:
Hi,
Thanks,
Andrew
I always thought the HKS camshafts had HKS as cast letters?
EDIT: Are you questioning if they're actual HKS or just the profile?
Discussion Starter · #3 ·
is this right?
I have already received them, just to confirme if they are real HKS. Also, one cam has A05-M 005 on it, the other has A05-M 006 on it. Are they 272s?
Andrew
HKS Camshaft Mitsubishi Eclipse 1989-1999 Turbo
Note: Sold as pair.
Part Number Application Spec. Engine Cam Duration Cam Lift (mm)
2202-RM005 MITSUBISHI Eclipse GST, GSX, Spyder GST 1989-1999 Turbo Intake 4G63BT 272 10.3
2202-RM006 MITSUBISHI Eclipse GST, GSX, Spyder GST 1989-1999 Turbo Exhaust 4G63BT 272 9.8
20 seconds of searching!:rolleyes:
There's your answer.
Discussion Starter · #5 ·
Note: Sold as pair.
Yes, I did, so, but I am suspicious of the 2202 doesn't match A05-R wording. The cams are tagged with A05-M006 and A05-M005, but not like 2202-RM005 and 2202-RM006. Thanks.
Andrew
Andrew
Those are part numbers, the m-005 and m-006 are the parts I focused on. is searched on the whole engraved string and came up with nothing of consequence.
1 - 7 of 7 Posts
